Acid does not register on my test strips
flymike
2
Sarasota, FL
I check my pool regularly with test strips, and occasionally take a water sample for testing to my local pool store.
While the pool is balanced as verified by both test strips and water sample, the various brands of test strips I have used never show a reliable acid level - that is, the sample color never matches any of the colors depicted for different acid levels. Further, my pool store does not measure acid level.
So I never know what my acid level actually is.
When pH does get high, I can successfully bring it down by adding acid, so this is not a big problem.
But I'm curious why I'm not able to get a reliable acid level reading.
Mike,
The only "acid" reading that I have seen on test strips is for CYA or Cyanuric Acid (Stabilizer).
This has nothing to do with the Muriatic Acid that you would use to lower your pH.
We call test strips, "guess" strips as guessing has about the same accuracy. :mrgreen:
Tell us more...
Reactions: Mdragger88
