Pool cover maintenance seems to be related to servicing and/or "cleaning the motor and other components of the housing." Aside from the motor this includes the 2 cables, their hardware, and the drain area. Pavers sitting over the housing box sit like shelves over brackets. In our case (as diagramed below), pavers sit on top of 12" x 24" shelves which sit over the brackets. Where and how much space needed for access?
I would assume that the areas around the motor, drain and cables require the amounts of access and that the pavers overlying these areas should be the easily removed. I shaded out areas in the second image below based on some of these assumptions and would appreciate if anyone else has recommendations based on their experience with maintaining and/or fixing their autocover.
In the example below, each grid/square is 6" x 6". I assumed that the area around the motor, drain needs the largest amount of access. Also, I shaded areas along the length of the cables in case the cables need to be repaced. The three 6x6 boxes in the middle area are spaced provide enough space to stick a vaccum hose in between to suck out leaves in the middle portion of the autocover box.
Here are some actual picture of the construction and how the cutout squares look.
Please let me know where you think the access cuts should be. Feel free to color over my diagram or represent this in any way you can. Your help is much appreciated!
