Last two years I setup and enjoyed for the most part an Intex Easy-set 15x48 pool. The design flaw of the material used on the top ring, and the constant deflation during thunderstorms or other rapid temperature changes, and then having to refill the volume of water lost at least six times let me to upgrade to a Bestway's Steel Pro 15x48 this season.
I made the same 1.5 inch valve modifications to be able to use my Intex sand filter 3000gph, and added an Intex Deluxe Skimmer to the mix. I am 100% satisfied with the design, easy of set up and quality of the new pool so far. I am amazed how well the skimmer keeps the pool clean, having to vacuum about half as much as I did with the Easy-set pool and no skimmer.
So the mysteries I have are why the pool water in this configuration is so much warmer than the past two years, and why I can't use both suction ports with the skimmer. The pool is in the same location as the previous one so same amount of sunlight etc hits it. Same filter configuration and running times.
For the first I would say its hotter this summer here than last two but it is just the opposite. June had no 90 degree days and nights were in the 50's for the most part. Only since July have we had 90 degree days and relative lower humidity than is historically typical in New England. So why is the water approaching 85 degrees now? I run the pump mostly at night but I do not have any spray or fountain helping to chill the water. I am also not covering the pool by day as I did with the other pool. I primarily did that to try to keep the inflated ring out of direct sunlight. Any way other than adding cold water to chill the pool water down?
The skimmer does an amazing job but it needs 100% suction to really do the job. I would like to let some water flow from the other port as a safety in-case a large amount of leaves clogs the skimmer basket even though it seems to have a safety valve on the bottom so it never starves for water, or burns out the pump. Is there some magic ratio to have both ports working or do I just have to sacrifice the skimmer efficiency part of the time that the filter is on? I guess water is going through the filter either way but I think if I have two ports I should be able to use both especially with the size filter I have running.
Thanks in advance for your advice.
