Hey all - I have an above ground pool in my yard.
One "section" of the pool is showing some rust and starting to flake away.
The rest of the pool appears intact w no visible signs of rust and seems solid.
It has created a small tear in the liner.
See pic attached.
On the positive side - the major rust is just above the normal water line.
On the negative side - I'm sure it's going to keep spreading without some sort of fix.
Any thoughts on repairs to get me another couple of seasons??
My initial thought was to take off the top rail in this section only; pull back the liner just enough to slide in a piece of sheet metal w some epoxy, duct tape around the edges of the repair steel, and patch the liner.
Any advice and insight would be great! Thanks!
See pic attached.
