Hello all! We had an above ground pool installed 3 weeks ago and the GFCI breaker has been randomly tripping. I have a Pentair 1 1/2 horsepower motor for a 24' x 52" pool. We ran the electrical ourselves. I made sure to run bonding wire to code around the pool and bonded to the pool frame itself (using one of the existing screws that hold the pool shell together since mine is a resin pool), bonded the pump, and bonded the water with one of these Amazon.com : Perma-Cast PB-AG Above Ground Water Bonding : Gateway We are using a GE gfci breaker and I also have a gfci receptacle that the pump is plugged into. The gfci receptacle is not tripping only the gfci breaker is tripping. After extensive research it sounds like this may be a common problem and the recommended fix is to use a Siemens gfci breaker due to having a higher tolerance to tripping. Since I do not have a Siemens panel I would have to do some extensive rewiring and such which is way out of the budget. So my question is can I do the following and still be good go to?
Normal 20 amp breaker -> 110v gfci receptacle in a weatherproof in use cover -> pump plugs into the receptacle
This way I'd still have gfci in place and it would save me a ton of time, trouble, and expense. Apologies for information overload!
