I think my above ground pool has a leak in the liner. It’s not possible to look for wet ground as my pool is 2.5’ in the ground. Being that it is winter time, how do you suggest I find the leak?
In some areas of the country you can let the water continue to leak (drop) until it stops which would indicate the height of the leak. But in MS your water table may be high and letting the water level drop too low could be dangerous. You might be okay with letting the water level drop about halfway. At that point, you might have to resort on someone with a wetsuit who can get in there and perform some dye testing. Just to be sure, have you checked your waste line to ensure water isn't seeping out from the multiport valve (bad spider gasket)?
