Good Evening, we finished putting up a 30 ft diameter Above Ground Pool. This is also my first post on this forum, and it looks like there is a lot of useful information, I'm sure I'll be back. One of the last steps I need to complete to comply with local permit requirements prior to the inspection is to complete the bonding step (which I've seen many posts on and am sure most are familiar with). One thing I've been trying to figure out is how to attach the 8 awg copper bonding wire to my pool in four locations? It is a metal shell, but the vertical supports and bottom perimeter track are plastic, so the only metal to connect to is the Shell itself, but I have no idea how to create a permanent connection to the shell with the copper wire...except at the wall seam where I can use a grounding lug on one of the bolts. As for the other 3 locations, any advice would be much appreciated! Thanks in advance.
