Hello everybody. 16x32 Intex Ultra pool here with the Intex Sand/SWG pump/filter. Water is being delivered on Tuesday. I’ve added a couple of inches of water already to work out the wrinkles.
Just want to confirm that for now the only thing I should buy is CYA and about 8-9 bags of 40lb salt and maybe some bleach.
How much bleach should I add at the beginning? I think the pool is around 13-14,000 gallons.
Probably going to add the salt as they are filling the pool and then of course run the pump.
I’ll worry about PH and adding Borate later. Test kits are on the way.
Thanks for any help you can provide! Kids are anxious. Took me way longer to get the ground level than I thought. But it is level!
Jim
Jim
