First 2 days hourly, and when they say it takes ALOT of chlorine it takes ALOT, mine took about 30 gallons of 8.25% bleach, and I cheated a little with my rainbow 320 over night, I set that on 1-1 1/2 to maintain then shut off and added only beach during the day, I started adding bleach about 4-6 hours after the treatment, you will be amazed how quickly the stains go away it's truly something to see, I also added twice the dose per day of the algaecide 60 while I let the FC to 0 and during the process until it started to hold, I also added about 1/2-3/4 lb of DE in sand filter to help filter the AA out, I had to use a bunch of AA to lift stains, some of the stains where 4 years old. As a side note I just ordered more powder and R-0871 you will want to have plenty of hand, I tested FC, CC, and PH hourly, seemed like I added about a gallon of bleach and 12-16 of MA an hour for the first 18 hours then it backed off on demand, be sure you are willing to babysit and test, test test before you start the process, although a long process it was very much worth it, I literly have a new pool to look at now, I was considering a new liner just because it looked so univiting, but not now!!!
Good luck should you decide to do it. For me it was well worth it!
This whole process now has me looking at going to a Stenner injection pump, I'm sold on TFP methods my pool in 16 seasons hasn't looked as good as it does right now!
