I had the perfect level of CYA in the pool before I turned the SWG on and it remained stable for over a year. No problems at all. So much so that I neglected checking the CYA for a few months and then it seemed to be zero. None at all! I thought my reagent was no longer any good, and had a sample tested by a trusted capable pool store; it was one of those new-newfangled computerized ones, and that test showed zero! CYA isn't supposed to go away, and I didn't do anything with the chemistry. I happened to have some CYA and put two cups in a cheesecloth bag, suspended it off a board in the deep end and it dissolved after about three days. My test kit still showed zero, and suddenly my SWG was indicating low salt. My tester showed about 4000PPM, so I inspected the cell and it was all clogged up with white stuff. I'm assuming it was the CYA. I cleaned it with acid and everything seemed OK. I have had there were no problems keeping the pool at 3-4PPM FCL despite the lack of CYA and lots of sun. The SWG was running for six hours at 70% and it's rated for twice the capacity of my pool.
So I'm really puzzled about the disappearing CYA, and also wonder how it can be added without clogging up the SWG again.
