I'm a little confused by the pool math app - "effects of adding" and "FC" are giving me different amounts. I'm trying to move from 5 FC to 7 FC using some 10% liquid chlorine that has weakened to around 5%. FC section of the app tells me to use 94 oz. However, "Effects of" is telling me that 80 oz is enough for that move. I also see the inverse on MA - pH section of the app will tell me a lower amount than "Effects of" says I need to move to my desired pH. I'm confused about the discrepancy between the two areas of the app and unsure which one to rely on for chemical dosing.
