We are new pool owners. We moved into our place in September. The gunite pool is about 18 years old. We had a pool guy come and clean the filter. We were told that our filter is too small for our pool and it would take 800-1000 to replace. After he cleaned out the filter the dirt area near the pool equipment was messed up. It was very wet and there was a gap between the soil and concrete. It did not dry up. The soil in that corner stayed moist. I tested another area with similar soil and it dried up within a day. I dug up part of the area and found the portion under the concrete pad to be moist. We called our home warranty and a guy came out and said there was nothing he could do because it was below ground. I see moisture on the concrete pad near the spigot that turns on the automatic water refill. I am going to do a bucket test. We have so many knobs and levers with this set up. I am wondering how to tell if there was a leak or if we did something wrong. It is a pool with a water feature, a solar heater, and an automatic filler. When I left for work this morning, I took a picture of the moisture. There is not usually this much moisture under the pool equipment. I don’t think it has rained overnight. The pool equipment has been off for about 10 days.
