- Jul 29, 2018
- 777
- Plaster
- Pentair Intellichlor IC-40
Most recent post I can find here on this topic is six years old, so I'm starting again. According to reputable sources, places like the Gulf South where I live a residential A/C can produce 15-20 gallons of condensate a day. Now there may be a little dust if you don't keep your air filters clean/replaced, and there could be a bit of bacteria from your home in the condensate as well (in your home, but not in mine ), but is that enough reason to throw away 20 gallons of 7 pH essentially distilled water a day? Our A/C condensate goes into the sanitary sewer system. Meanwhile we buy a comparable amount of 8 pH from the city to compensate for evaporation...and then we buy muriatic acid to bring the pH down.
I'm seriously considering collecting my A/C water in a barrel and then running a hose from the barrel to the pool. No that water isn't strictly potable as is, but I have UV, Ozone, and chlorine to treat it, just like the rest of the water in the pool. Further, since it is cool water, the peak of summer when A/C runs the most and humidity sits at 80% plus, that could even contribute a tiny bit to lowering the water temp--which can hit 92 degrees or more. And since down here in the south we run our A/C and pools 12 months, this is a year 'round issue. In fact, I can't help but wonder why the environmental lobby hasn't mandated recovery of A/C water. Is anyone here doing this? Here are a couple of articles. One specifically mentions swimming pools as a place to use the condensate.
Potential uses for condensate recovery:
Potential Uses For Reclaimed Air Conditioning Condensate
Condensate for plants:
StackPath
StackPath
