I drained the pool out to about 6" above the deep end area. I am guessing this is about 1/2 of the water. I hope this will lower my levels and increase my clarity.
Luke Pools
Luke Pools
How about "Chemtura is lying to its customers to maximize its profits." ?chem geek said:lukepools,
I don't know how to say this in a politically correct way, but the relationship between chlorine and cyanuric acid (CYA) has been known definitively for at least 34 years and higher CYA levels do make a difference in spite of what Bioguard (Chemtura) is telling you.
Richard
That's amazing that they said that, but didn't define "proper chlorine" to be an appropriate FC/CYA ratio. Of course, talking about CYA means not using as much stabilized chlorine which is a primary product that they sell. Though what they say is technically true about other phosphate "food" sources, it does appear that getting rid of the orthophosphate (which gets rid of phosphoric acid and its relatives) does seem to work to prevent algae. Perhaps in most pools, it's the primary source of phosphate for algae. It's like using PolyQuat 60 weekly -- it's not ineffective, it's just extra cost and unnecessary if one maintains the appropriate FC/CYA ratio.spishex said:They also mentioned the ability to prevent algae with proper chlorine levels despite any level of phosphate...
Take a look at this thread from The PoolForum (I copied it to my account since not everyone can access The PoolForum anymore). One can usually clear a pool with algae in about a week or less, but one has to use a sufficient amount of chlorine. The problem doesn't seem to be so much having a sand filter as not having a floor drain as with most above-ground pools. In those situations, the poor circulation can certainly delay the speed of clearing the water, especially in pools with weak pumps (i.e. Intex pools with original pumps).Heckpools said:When you have a sand filter with bad algae or cloudy water, i really feel there is no other way besides flock... i mean there is.. but who wants to wait weeks.. i know my customers dont. and it make you look bad, even though it has NOTHING to do with u or your company.
My comment was not directed at you but rather at lukepools. He had a cloudy pool with some major water balance issues and WAY to little chlorine (and apparently not a lot of knowledge of how much chlorine he was actually putting in as per his putting in 2 lbs. of 35% lithium into a 20k pool and thinking that was 'shocking the pool'!) I agree with you that floc is the fastest way to clear a pool that is cloudy because of DEAD algae (and the easiest way when you have a DE filter). Pros usually have the patience to vac to waste properly!Heckpools said:WATERBEAR- well that ios just common sense ( i hope so anyway) i didnt mean that the sand filter was the problem, what i meant was if a customers doesnt take care of the pool and it turns into a swampy mess... having a sand filter is going to slow you down. Ive delt with many green pools... ones with sand filters always took the longest to clear.
also, a cloudy pool due to chemical imbalance i wouldnt use floc to clear up lol
but maybe a cloudy pool due to dead algae floating, is where id use the floc.
Though I love a lot of what my PB did with our pool, he didn't put in a 3-way valve to be able to vacuum to waste or drain the pool, etc. I haven't needed to do it, but it would have been nice to have that option. I'm glad you're thinking ahead.Heckpools said:CHEMGEEK- any pool that we build here that has a cartridge filter we install a 3 way jandy at the top of the pump. one line goes to the filter and the other to a waste line. This helps SOO much when you need to drian the pool, or vac. to waste
What 25 different chemicals? Which test kit do you have? I am intrigued. Since you mentioned watergram I am assuming you have a Taylor kit. They do not make a pool kit that tests 25 parameters. Their pro slide combo really only tests 10 (and that is including acid/base demand and total and Magnesioum hardness, which are not really applicable to pools). Even if you add tests for borates and phosphates, biguanide, peroxide, and salt you are not anywhere near 25 different water parameters. LaMotte, Hach, and Palintest do have some colorimeters that can test that many water parameters but most of them are really not meaningful to pool/spa water testinglukepools said:My current test kit test for 25 different chemicals. I used my water gram and its balanced now.
