Good news that it is dropping less. FC will hold better overnight with the sun off the pool. Just keep raising the level back to shock. You can move it to 15 or 16 in the morning before work to help through the day.
The last time you test and adjust tonight, take it up to 15ish.Alright so pretty much every hour up until 4:00pm, we were adding 2 gallons of 8.25% as FC was dropping to 3.5-5.5 between 12:45 and 4. 5:30 it only dropped to 8.0, 6:30 dropped to 6.5, and now just at 7:30ish it only dropped to 9.5.
Let me know what you guys think and what I should do in the coming hours right before I head to bed, and what you may suggest for in the morning.
Thanks everyone for their valuable input.
The lights are usually held in by one screw at the top. Those of us with normal length arms can lie on the pool deck and reach down to unscrew it. The standard is that there is sufficient cable coiled up in the light niche to reach the pool deck for bulb exchanges.Im sure I'll be swimming to the bottom to pick up screws too....no idea how Im going to do this while treading water......maybe I can rig up a sling around the diving board somehow
Some manufacturers are nice in that they ave an "O" rink on the screw so that once its loose, the screw is held captive and won't drop out.
