You need to raise FC
CYA of 60 no SWG FC should be min 5 target 7
Pool School - Chlorine / CYA Chart
Well part of the mystery is solved if the current readings are accurate. I suspect that either the first pH readings indicating a pH of 6.8 were wrong or that you already had some carbon dioxide outgassing raise the pH. At any rate your saturation index is now near zero so the cloudiness should slowly dissipate, but your pH may continue to rise and if that happens the cloudiness may remain.
So what you can do (after raising FC which is more important right now) is to lower the pH with acid, probably to around 7.2 by adding 12 cups of Muriatic Acid slowly over a return flow with the pump running and then brushing the side and bottom of the pool in the area where you add the chemical. That should clear up the cloudiness. Then, over time, you'll probably need to add acid to keep the pH from climbing too much. You can just see how it goes and if the rate of pH rise and acid addition is too much, then you can consider lowering the TA following the procedure in the Pool School, but it's not necessary unless you find the rate of pH rise to be too fast.
