- May 23, 2015
- 24,474
- Plaster
- Pentair Intellichlor IC-60
The Taylor #9198 test tube has multiple graduations on it for different sample volumes. On the FC/CC tests one uses the 25mL mark for 0.2ppm/drop resolution and the 10mL mark for 0.5ppm/drop. Does anyone know what the test resolutions are for the other graduation marks?
The FAS-DPD test is easy because the DPD powder amount does not have to be exact (just saturate the solution with indicator dye). The TA and CH tests would be harder to change as the other reagent and indicator drop count would need to change for different sample sizes.
Thanks!
Thanks!
