The old booster pump was supposed to be the only thing re-used. However, I discovered the plastic board the electrical connections were on was dry rotted and in pieces. The connections were free floating. New booster pump wont be delivered until mid week to finish it up
The 3/4 ball valve though will go to the booster.
I had a lot of Sch 80 true union ball valves and some unions left from my old reef tank so figured I might as well use them. Lots of unions and threaded joints to create more possible leaks, but easier to tear down only sections as well. Currently, no leaks
Outlet side of the sand filter took a couple shots to get it leak free. I also intended to have an extra union before, and after, the pump but forgot to pick them up. Then I forgot I meant to add them so that Jandy check valve is right smack in the middle and can't easily add a union now. The vertical rise from the pump though is a little short and needs the union added when I can.
Otherwise, I need the new pressure pump and will be almost done
I paid the electrician to add the sub panel. I paid the pool place to take care of only the final cutting of the old pipes to tie in the new and did the rest myself. Onward and upward!!! Now to get the SWG and Aqua Logic in use and find more toys to add
