PH level before the SLAM
Hayward sp15922s powerflo matrix 1 hp 2 speed. 115volt
Read reviews on amazon. Did some searches on here about 2 speed pumps with sand filters.
Plus all my current plumbing is going to work with it.
Yeah the energy savings was a big a plus
Sent from my XT1080 using Tapatalk
Cool! You can use all the money you save to buy bleach and test kit refills ;)
I would also suggest The Sample Sizer as well and then you'll truly be Mr. Pool Science....
Well time to update my woahs from last years over chlorination debacle.
I knew I was going to replace the liner so I didn't worry with covering the pool but I guess I should have to have prevented the swamp! Literally had frogs and algae blooms like lily pads ha.
It was a time getting it drained.
Well finally got it down to sand
And dun dun dunhhhhh
the end result! Didn't take much pictures while putting the liner on. Had moments of frustration during the install (trying to get the liner get reed and all the wrinkles out. The shop vac def helped get rid of them eventually.
Very pleased with the end result and the darker color of the liner especially compared to the bleached liner. Def can tell a difference from the top ring of the first pictures and the parts that were under water.
nice! that looks like a big pool!
Sent from my SAMSUNG-SM-G928A using Tapatalk
Yes... A 30' round. Before switching to the TFP method i was really regretting buying that size since some smaller ones were on craigslist. And pool store chemicals are SO expensive. But we're the same price or more expensive. ($500 was a bargain for the pool and pump and filter but I had to take down and put back together. But that's the way to go so you know how to put it back together)
I personally will be glad, when we get our house, (this one is a rental,) then I will be able to put up a real pool. I personally am not into the taking down every year. too much work. oh and I want mine to have a dark liner like yours. it's beautiful.
