Hi emjohn. Yes, we do have wasps coming out of our eaves, which is not good. But we haven't had time to do anything about them yet. There aren't nearly so many hanging around these days. I hope that doesn't mean that they're in the attic/walls doing their stuff! The bees I've been rescuing from the pool are the little honey bees, as well as the gargantuan big bees, which I assume are connected to the honey business in some way - they have the hairy hind legs. Unfortunately, we aren't trapping any wasps in the skimmer - I would have little mercy for them!
I had originally wanted to hard-plumb, but leave the pipes on top of the ground under the decking (which we won't have for awhile) and just cover them with the foam insulation tubing. But DH said "NO" and he's right. Putting them in the ground was a better thing to do... as long as HE had to do all digging
As suggested above, we will cover the above-ground piping with the insulation tubing and I don't know about the pool equipment yet. I just don't want to have to drain everything and take anything apart and all that mess. I just want to do it the lazy way, if I can find an adequate lazy way
I expect if we at least get the little enclosure built around the equipment that it will keep the equipment from freezing up, like in case we lose power.
We're like y'all. We've only had our pool since May and I just feel like the mother hen and want to put the hat, coat, mittens and earmuffs on the pool "just in case"! Our case is a bit different in that we had our Doughboy buried - so we have extra things to be very careful of. Like if I mess something up and we have to replace the liner, that would not be good. If we drain our pool, chances appear strong that it would cave in from the ground pressure around it. I haven't studied all there is to that because I dread the day we have to replace the liner. So if I don't study it, I won't ever have to replace it, right?
I hope y'all have enjoyed your pool as much as we have. I would have enjoyed it more had I known for sure that the poofy stuff was only pollen. But NEXT SUMMER.....
:sun:
I'm SO glad to have found this site and the wonderful moderators, who have made maintenance a no-brainer! I'll keep you posted on how ours goes. My main concern in this posting was that enough thrust/movement would be in the water, both in the pool and in the pipes, that we woudn't have to worry about freezing up. Our 1hp/1-speed pump runs us about $75/MO to run 10 hrs/day. The new 1hp/2-speed pump should run us about $36/mo to run it 24/7! I'll just need to remember to check the water level. That reminds me, I need to go order some more supplies from Duraleigh! Have a great day!
