What about 8.25% bleach prices at your local grocery stores? $3.50 isn't bad though.
Get the Cya down and stock up. You can boost the FC to SLAM level, but with the Cya higher than you may even know, it will be a waste. Slamming with even 100 Cya takes an unreasonable amount of FC to get the job done. A staggering amount to be honest.
A little more math, because posting it reassures me.
With my somewhat inacurate (due to dilution test) measurement of 200ppm CYA, I get the following.
Starting CYA * 2/3 volume = Resulting CYA * full volume
200 ppm * 17.3k gal / 26k gal = ~133 ppm
133 ppm * 17.3k gal / 26k gal = ~89 ppm
89 ppm * 17.3k gal / 26k gal = ~59 ppm
59 ppm * 17.3k gal / 26k gal = ~39 ppm
Obviously I will retest after every drain and fill session (I have extra CYA reagent as well as FAS/DPD on order from tftestkits), but I believe I have a minimum of 3-4 to get this done. (safely) I don't look forward to my water bill, but it beats having a swamp in the middle of the deck.
