WF 2.0 is leaking water and is a power hog. I not sure if I should go 2 speed Centurion® line of pool motors or a VS pump.
I was trying to base that on pump speed to clean pool, If it was 1500 to 1700 rpm then I would go with a 2 speed. IF was
1000 to 1200 would use VS. I run my pump now 4 hours a day and is crystal clear !!!
The booster pump is for the spa.
Minimum flow, GPH to clean a correct question?
OK sounds like you are looking at the right options. Just a 2-speed motor replacement is going to be significantly cheaper upfront that an Intelliflo. Your electric rates are pretty high, so the VS should eventually offset the higher initial cost, but it may take a few years to do so.
SCE has a time of use plan here, It allows me to use my pump from 10pm to 8am for .11kwh.
Most 2 speed are 1700 rpm, Is that enought for the navigator pro?
Well, with the cheap power, that makes the VS less of a good option.
A 2HP Whisperflo is a big pump (Which pump do you have? What is the service factor and HP rating?) that moves a lot of water, so it might be enough on low speed if all the suction is to the cleaner and you are not trying to skim at the same time.
Pentair WFE-8 , skimmer and cleaner work at same time.
Product No. Model Voltage HP S.F. Full Load Amps
011515 WFE-8 208-230V 2 1.30 11.0-10.2 55
On my aqualink rs, how can I tell if I have more room for the 2 relays it will need ?
