I will try not to make this a story.
Pool
Lost pool cover in Jan. Some leaves in bottom of pool.
Have been dipping off and on for most of day. Most are in the center now.
added 2 pds granular sanitizer that i had laying around yesterday before i found the SLAM instructions so
know i have no idea if my PH is correct. Got up this morning i was able to at least see the brown blobs of leaves (couldn't
see that yesterday) and
added 2 gal of liquid chlorine kemtec brand this morning .
Went to town could not find the FAS-dpd kit at leslies so i got the DPD kit and have tested my water
according to the instructions. This is what i got with the test Kit
FC 5ppm
TC 5ppm
if i calculate it right that would be 0 FC correct?
CYA 35PPM
PH has got to be above 8.0 because its color looks to be brighter then 8.0
So i have looked at the chlorine/cya chart but i am confused. I do have a salt system but it is not plugged in right now
as i figured it more important to get the green out of the pool first.
So, do i need to stop and get my PH correct and then proceed with the SLAM?
Do i follow the chlorine/cya chart for a SWG or NonSWG?
Just a few of my million question :grin:
well i guess my siguature didn't add so here it goes:
East Texas
16x48 above ground metal frame intex pool
new 1500 filter pump
intex salt system
Pool
FC 5ppm
TC 5ppm
CYA 35PPM
East Texas
intex salt system
