I'm designing my own DIY intellitouch system and have a question.
They have a power center, and a load center, which houses the intellitouch i5 panel.
It's intended that the load center be used for pads which don't have a sub panel, or have runs from the house panel, out to the pad.
The power center, it appears is a small form factor housing for just the Itouch panel, and the relays and connections necessary to run the automation
I'm assuming, and this is where i need clarification, that if i have "home runs" from the pad to my main panel, that I can just run the power center, which doesn't include breaker spaces, correct ?
