On TA: anything in the red/pink range counts.
On CH: dots/lines are common and can be ignored.
On CYA: you should replace water to get the CYA level down. How aggressively you work on this depends on what your CYA level actually is. You can do the CYA test again with dilution (mix equal amounts of pool water and tap water together, do the CYA test on that, multiply the result by two). This is much less precise, but will tell you if the current level is around 100 or more like 200+.
