Hi Everyone,
It has been many years since I was here last. Sorry but all was going great after learning how to maintain my pool here. THX.
My return/revisit today is that I plan on draining 50% of my pool after 7 years. The reason is because my chlorine is being eaten up and my CYA has gotten lower and the test show I have contamination from rain and other issues that I won't get into but some wrong chemicals added while I was gone by my daughter. So instead of playing games I decided to reduce my water level by 50% and refill with fresh water.
The pool opened February 2008.
During this time everything worked well.
SWG cleaned every 6 months
Cleaned filters 3 or 4 times a year
Water has been basically well balanced chemically until the last 3 months.
My PH is perfect as well as all others but my chlorine is being eaten up very quickly.
Water super clear, No algae.
Yes I still need to refill 50%.
Normally these are my readings.
FC levels 1-3 ppm
PH 7.2 to 7.6
TA 110 - 130
CYA 80-100
CA 250
Salt level 3200 ( Goldline limits 2700 -3400)
PLAN IS................
Start draining pool down about 50% which is about 5,000 to 6,000 gallons.
As I'm draining I plan to acid washing the tiles at water level to remove 8 years of calcium build up.
1. After filling back to level I will install four new filters.
2. Next I will start adding CYA over a few days and test regularly to insure good reading.
3. I will add initial liquid chlorine but haven't decided bleach or pool store stuff. After that the SWG will take over.
4. Will add approx. 100 lbs of salt as I figure my salt level will be divided in half down to 1,500 and to get back to 3,000 the chart says just over 100 lbs.
4. I will run pump on a regular schedule and test, test , test.
My questions now are...
1. Does this plan sound reasonable with the proper order I need to do this or does it need modifications?
2. Can I use liquid bleach or just use liquid chlorine from the pool store before switch back to my SWG?
Thanks in advance and hope to hear from you all soon.
I will also post how things are going but I have to wait another week to insure the rain stops here in the Arizona desert.
FC levels 1-3 ppm
PH 7.2 to 7.6
TA 110 - 130
CYA 80-100
CA 250
