Just added a bunch of CYA and ph has dropped to 7.0 (or below). I read in here that CYA affects ph but should I add borax to bring the ph level up or just leave it? TA = 70.
Ben.
Ben.
What test kit are you using that only goes to 30 ??
I use the Taylor K-2006. I mean the lowest number the tube goes to is 30, which is at the top of the little tube.
0 to 90 would have required 16.5 lbs of Stabilizer
CYA was at zero so I add 8 lbs. might have overdone it because now it's ~90 (have trouble reading this test). hoping 90 will be ok.Gotcha .
But he wasn't going to 90 he just thought he was at zero and was trying to get some in there.
