Manual cleaning or Robotic cleaning... which do you guys prefer?
I am considering a Aquabot or similar.....
-inBamaNow
16x32 Hydra Liner, Hayward 24" Pro Sand Filter, WhisperFlo 1HP Pump, Hayward CL200, AquaChem Test Kit =[
It's your choice. Most auto vacs do a good job of getting out most of the debris from the pool. It becomes a question of "is having the auto vac save you 1/2 hr/ week vacuuming worth the cost of it?" However, even with the best auto vac - there will be times you have to vacuum manually![]()
A lot of folks find it a nice break and even relaxing to vacuum the pool manually, but if you don't have the time or find it to be a PITA and can afford it, get the auto vac 8)
Luv& Luk
-Ted
Yep, and I'm one of them, it's the only time I can enjoy the pool by myselfA lot of folks find it a nice break and even relaxing to vacuum the pool manually, but if you don't have the time or find it to be a PITA and can afford it, get the auto vac
Plus i don't even know if my pump would be able to handle the auto vac!!!
24' x52" Intex metal frame
Pentair sand dollar SD60
Original pump 2500gph
"5 years of BBB, and loving it"
If you do decide on a robotic think about a remote control. I have a Dolphin w/o a remote, and wish I had one.
IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
http://www.tftestkits.net/
