I have just finished hooking up my Liquidator, and before I start iy up, is there any thing I need to check for, any suggestions, any insight from anyone before I get it going?
Poolidiot said:Well I removed the check valve on the output side and I now get flow. Duraliegh this may be a question you might could find an answer out for me/us. Why do they supply and tell you to install a check valve on the output side , when putting one in makes it NOT work and it works with out one?
kmb997 said:Poolidiot, can you tell me the sizes of that tee and what kind of fittings you have coming out of it?
Thanks
Rabbit said:So in the case of an above ground pool the water might (and should) back flow in the LQ causing the tank to overflow.
Rabbit said:The check valves mentioned can be disassembled and the springs altered (or even removed) if needed to adjust the pressure setting.
Poolidiot said:Rabbit said:So in the case of an above ground pool the water might (and should) back flow in the LQ causing the tank to overflow.
Mine is an ABG pool, so you are saying I am screwed with out one?
Poolidiot said:Rabbit said:The check valves mentioned can be disassembled and the springs altered (or even removed) if needed to adjust the pressure setting.
I leave for vacation Tuesday morning, thats all I need for my LQ to over flow while I am gone. You say I can take the valve apart that came with the LQ and remove the spring and it will work? Are they made where you can take them apart?
