I was sitting by my pool a while back enjoying an adult beverage, just spacing out at the absolutely crystal clear water you and I have created together. It was getting pretty dark outside and I had the underwater light on. I started to hear some frogs. Then I started to see some frogs. Then there were probably 15-20 little frogs having a pool party. They were jumping in and swimming around and chirping at each other like they owned the place. I've never seen frogs use a chlorinated swimming pool before so I can only assume that it's because of the ph balance and the lack of chemicals that allows them to come and go unscathed. It's been like that every night for a month now and I haven't found any corpses so I can assume that they will be fine.
I think they are adorable and I don't mind sharing the pool with them as long as they don't mess it up. Is this normal and should I worry about them or the pool?
