Wiring SWG into an integrated AO Smith timer
:wave: Welcome to TFP!!!
Sorry for the delay. I am a little confused though. Most 2-speed motors do not have timers built in to them. Can you post up more information and maybe pictures?
I is usual to power the SWG from the same timer source as the pump, but the timer is not usually integrated into the motor itself.
I don't believe they have any kind of external control connection. You will either need to use an external timer or get something like a current controlled relay to turn the SWG on only when the motor is drawing power.
