Jason, perhaps I should have said something like most common ones will interchange, however there are several that I have seen on sites like ebay that will not. The GL-235 in question uses a 24V actuator, there are also 12V actuators, as well as solenoid operated diverter valves. Additionally the solar temperature sensors have limited interchangeability as most / all use use some type of 10K Ohm Thermisters for their temperature sensors, the problem is some brands use different response curves than others, which tend to have minimal differences if used as matched sets at normal pool temperatures, but if used on controllers that use the sensors for freeze detection they cab be off by about 10 degrees at 32 degrees F..
Ike
Ike
