Thread: Pump rebuildable?
    May 2008
    Des Moines, IA
    16
    Pump rebuildable?
    I have a Sta-Rite 1hp pump, model JWPA5EL-2A that is leaking at the shaft seal. Any idea if this pump can have the seals and bearings replaced?
    Inground 14'x28'x4' flat bottom kidney Vinyl
    Dynamo 1hp - Pac Fab TA-40 Sand filter 1-Skimmer 2-Jets 1 bottom Main Drain
    10,500 gallons
    crewchief47's Avatar
    May 2008
    Windsor, ON
    60
    Re: Pump rebuildable?
    I just bought one of these and the manual has a parts blow-up. I believe the website had the manual online.....
    http://www.pentairpool.com/techinfo/dat ... p?d=2&s=42
    In the above ground section under jwp(they're all very similar)
    Esther Williams 24', sunk about 36" into the ground.
    Jacuzzi Maxiplus 190 sand
    Sta-rite/aquatools 2 speed 1HP (JWP series)
    May 2008
    Des Moines, IA
    16
    Yes, that's the beast. Thanks very much!
    10,500 gallons
