If your FC has actually gone to zero I'd prepare for a SLAM. You'll know for sure once the OCLT has been done.
jblizzle said:Raise the CYA with stabilizer (this will also lower the pH some)
duraleigh said:Disregard the effect of CYA....it won't be enough to get you out of acceptable ranges.
You could calc lowering to 7.6 if you like but, generally, the compensation is not necessary.
Bama Rambler said:What is your TA now?
pwrstrk said:I would shoot for a CYA of 30 for SLAMming.
cya can take a week to show up in test so if you think half of what you started with is already in the water (regardless of what the test says now), I would take the rest out.TN94z said:Well, I put enough stabilizer in there to bring me up to around 60-70. But I have it in a sock in the skimmer right now, so I guess I can just test the water each day and remove the sock once the cya gets to that level.
pwrstrk said:How much CYA do you think you added ? Did you use the pool calc ? Test it earlier to see what you come up with. If you want to wait till the weekend to SLAM that's ok. Use the pool calc to figure out your FC shock level.
linen said:Unfortunately, since you put it in the skimmer, some of the cya may be in your sand filter. Normally we say not to backflush for a week if you use that method, but since you need to do the SLAM process, you will probably need to backwash much sooner, and that may mean you will loose some. My preferred method for adding cya, especially if you are in need of the SLAM process is to hang the sock in front of a return.
