During the SLAM process, unless you are doing an OCLT, you can go with a 5 ml sample of pool water, then each drop of the R-0871 is equal to 1 ppm FC (i.e. multiply number of drops by 1). That is enough precision to do SLAM dosing.jodyliebing said:would you be able to answer my question above about mixing my reagent with water? I would HATE to run out at this pointlinen said:The sun does a good job of lowering FC over a couple of days...keep in mind you can safely swim up to your SLAM level.
By the way, I fixed how you were doing "qoutes" in your previous post. Go to the edit function on that post to see how I did it.
