Thread: Parallel or series cell installation?
    New2Me's Avatar
    Jun 2008
    SW Indiana
    322
    Will it make a large difference in production to have cells in series? Will the salt level drop of the first cell make the second much less effective? I'm thinking of two Intex AGP SWC for my ~24,000 gal IG pool. I can either put them in series on my heater out line, make a T for two, or go further downstream and put one on each of two returns(least cosmetically pleasing.) Either way, I plan on just using one flow switch, and separating the transformers from the controls, and all of it from the bases. Wallyworld has these for $180 shipped to store, so I'll have a total of $360 invested, with a cell replacement cost of $360, if both go at the same time, plus extra flowmeters, controls and transformers. If I go the return line route, i might just go ahead and put in three, and make a bench to cover it all up, that way all of the water is treated. Does this sound too crazy?
    22 x 40 IG vinyl lined, 23,570 gal.
    1 hp. Pac-Fab Challenger pump 300# sand filter
    Intex 8110 SWG, Hayward CL220 offline feeder
    Hayward 250K Btu gas heater
    Aquabots
    Jul 2007
    Brisbane, Australia
    874
    Re: Parallel or series cell installation?
    with just 2 cells it won't make much of a difference
    SWG only uses a fraction of salt that's in water.
    Apr 2008
    Central Texas
    326
    The Intex web site is criminally devoid of any useful information about the product, but from the pictures it looks like the diameter of the actual cell is pretty small. You may need to install in parallel just to make sure that enough water gets through your current system.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    New2Me's Avatar
    Jun 2008
    SW Indiana
    322
    I was kind of worried about the restriction too, that's why I'm now thinking of going into two of the three returns, that way the third is a "relief" return. When I look at some of the IG systems, specifically the Zodiac, I wondered about the restriction the U in the piping causes.
    Aquabots
