Yikes thats cold! How much sun does the pool get?
That's a VERY nice build. Thank you for sharing the progress.
Looks great, what sort of coping are you using? Will the cement sit on top of the existing wall? How wide is the perimeter concrete going to be, around the back and sides? What did they back fill with? Did they tamp it? Thanks, some warm weather will warm it up. The water looks very good.
Nice pool. Two questions, how did the outdoor carpet work, I'm guessing not good since you are dropping? Do you mind sharing the cost of the concrete pour and patio size? If I could do everything all over, I would pour more deck. I am considering extending the existing patio but I am also thinking of using astro turf instead.........I wonder if the astro turf end up being problematic so your outdoor carpet experience might help.
Outdoor carpet was a problem over the rocky base. It's 1000sqft around the pool. The concrete was $4.50sqft. Holding off on the coping and pavers till next year.
The stairs in the deep end rock
Such a cool pool! (no pun intended) The steps are terrific - I have a thing for steps! I like how your PB bumped them out so not to take up swim area.
The liner color is gorgeous! The trees are the best - what beautiful country. Did you have much trouble with the trees shedding into the pool? As long as I could manage it, I'd have to keep those wonderful trees!
I can't wait to see the deck completed! Thanks for coming back to keep us updated. Have a great day! Suz.
Sorry for all the questions, but my build is similar to yours and I am learning as I go.
What did you do for the bottom? Sand? Verm? Concrete?
Are you letting it sit so the soil settles prior to pavers? I am torn between getting my concrete block / vinyl liner pool to the same state yours is in, water in it,, but waiting until next spring to pour concrete deck & perimeter. Both have pros and cons, but the soil setting could be a real problem, I used crushed limestone, rock and send as backfill, but I had parts cave in so I have topsoil mixed in parts.
Thanks again and your pool looks great.
