1) You've been posting all over the place with the same questions in
hokie pride algae issue and at the end of
Pool Opening - Ice/Algae Issues this year - Opinions Please and have an earlier thread
uncovered pool and need help that precedes this one. It is difficult to know where to post answers to your questions and it is harder on the moderators to have to consolidate threads.
Yes, I have been posting all over but it wasn't on purpose. I have spent over $1,000 on pool chemicals ove rthe summer and used my pool once this season. I have pumped off a lot of water today, broke my filter {luckily I had a second pump fingers to switch the handle to}, got the telescopic vacuum handle stuck in a severly extended position, filter contnues to lose suction and I've run it for two months straight changing DE like it was nobodies business and yet still have this dumb algae in my pool. I'm frustrated and just bought this home with a pool out of season. When I forst had it opened algae covered the bottom and I probably got rid of half of it. I'm sick of it and don;t understand what else to do to get it to dissappear so I can stop running ,u filter. By the way, I have 3 pool stores around me and none of them want to come help. They just want to sell me SH*& and talk on the phone like it's some hotline. REALLY? Because of you all I made progress but not finished. The algae on the bottom is yellow colored but won't freaking go away.
2) There is no indication that you have purchased a proper test kit, either the TFTestkits TF-100 or the Taylor K-2006. Without a proper test kit, your numbers may be completely wrong and it will be very difficult to help you on pool water chemistry issues including clearing algae. You cannot do a proper SLAM procedure without a FAS-DPD chlorine test kit since you won't be able to measure your higher FC levels with other kits. Also, you have no idea how high to raise the FC level if you do not accurately know your CYA level.
This test kit is on order!
3) You seem to be using algaecide so seem to be following pool store advice and mixing it with advice from this forum. That is unlikely to work since many pool chemical products have side effects or are not effective for particular issues. Is the algaecide you used
InTheSwim Algae Clear? It looks like this is Polyquat where the ingredient is Poly{oxyethylene(dimethyliminio) ethylene(dimethyliminio)ethylene dichloride} at 60% concentration, is that correct?
Yes! This is correct!
4) You give no indication as to whether your pool is vinyl, fiberglass or plaster and whether it is colored. Please put that info in your signature.
Pool is plaster in ground!
It sounds like perhaps you have yellow/mustard algae. If your pool is colored (say, blue vinyl), then yellow+blue looks green. Is the algae (if that's what it is) mostly on the shady side of the pool or is it just settling where there isn't much circulation or in seams?
Settling where not much circulation!
Do you have trees or plants nearby that could be blowing pollen into the pool?
There can't be that much pollen in the area. I do have a few trees and bushes around the pool and outside of it!
Does your pool have a floor drain or pop-ups? If not, then the bottom circulation may be poor and the chlorine may not be getting to the bottom of the pool to kill the algae there.
Can't tell if it has a floor drain! Too much algae flakes! Shouldn't the algiside have killed it!
How many returns do you have? Point them diagonally downwards to create a circular swirling motion around the pool and towards the bottom where the algae is located.
How do you point them? I have two returns!
