Thread: Order of functions for Pentair Tagelus filter lever?
    I recently moved into a new house with a pool that has Pentair Tagelus filter and never lived in a house with a pool before. The sticker identifies the fuction of the level has faded and peeled off and I can only see backfill, recirculate, and rinse. I can't seem to locate the slot for filter. I looked for manual but it doesn't show that area in question in detail. Any help will be appreciated!
    frankthailand's Avatar
    Apr 2008
    Thailand
    152
    Hello Sam
    I have a ta 60 and starts the same going clockwise, backwash, recirculate, rinse, filter, winterize [this position is where the handle does not go in the notch it sits between filter and waste, mine has that imprinted on the plastic in between the notches if you look closely ] waste, closed, and back to backwash etc.
    hope this helps
    get back to me if you have any questions
    Happy swims Frank
    Hello all from the land of smiles. Thailand. 5mx9mx1.5 63000L 16300 gall, pebbletex,
    pentair 1hp whisperflow, tagelus TA60 SF, swg monarch esc24 {a bit small for the tropics} 3 returns, 1 skimmer, 2 astral 100watt lights. Planned and built by me
    an AUSSIE expat living thailand for 18 years.
    I tried that and water was pouring out from the waterdrain pipe non-stop at full force. I had to stop it after 30 sec or so because the area was getting flooded. Faulty equip or different slot? Only setting the water won't come out is backfill. Recirculate setting also floods the area as wel.
    Apr 2008
    Thailand
    152
    Hello Sam
    Do you have the model number of the filter, and or the mulltivalve, does it have 6 notches, it might be faulty. But if you any more info maybe i can help, is it a side mount or top mount.
    Cheers Frank
    Re: Order of functions for Pentair Tagelus filter lever?
    Sorry for late reply but this thread sort of disappeared and reappeared. Any everything is working fine. I am an idiot, that is all. I was thinking that the location of the level was what mattered instead of the small piece that was in the slot itself. I have been running filter pretty long, using more chlorine and backfiltering. Plus algecide. Those things got the pool cleaned up real fast! Now my my family can enjoy the pool! Thanks again for the info! Now if I can only figure out how to operate the little waterfalls at the end of the pool!
