Re: Heavily stained fg pool with red/rust scale? (pics attac
Amazing instructions! Thank you so much for being so thorough!
I mopped the pool tonight....I noticed that the brush (although fairly new) was doing a bad job of cleaning the walls but my thumb did a great job, so I got one of those old sponge mops with no metal parts and started mopping. I wiped and rinsed every couple of feet. I got a lot of stuff out of there! I am so pleased with the results, that I have attached a picture! This picture was taken in approximately the same place that the picture showing algae and finger marks was taken. I was able to clean the walls very well. The bottom, I couldn't reach with my mop. I will have to vac to get that mess.
I read your post carefully and then read it again several times. It does make sense. I just have a couple of quick questions because I don't want to waste time or money. Should I vac the entire pool on waste before I start adding chemicals, or will the chemicals clean it all up? I have a cartridge filter, so I can't backwash. I have to pull the cartridges out and clean them carefully. That process takes at minimum an hour.
Also, I have already started adding the cya as directed. Do I complete that before I start to raise the calcium hardness?
Thanks again so much!
