I purchased an ammonia test kit which read up to 8ppm, my test was darker than the limit so I'm not sure how high it was. I am in the process of doing a series of drain and fills. What's a workable ammonia level? Before I start the schock process, do I raise the pH and add stabilizer? I'm assuming the pH will be right around 7.0 as it will be mostly fresh tap water and the stabilizer will be lower. How much LC do I add to start? Do I shock to the level of the CYA chart or higher because of the ammonia? I've read any where from 7-10x ammonia level. TIA!
