OK, so after some investigation, the previous owners of the house here were using a pool service person to care for the pool. When I got the pool, it was a disaster. Cloudy, (but not green) and the equipment was, well, hammered. Fast forward to now. Pool is crystal clear. Finally got my TF100 kit and here are my concerns/questions. Well first off, here are my test results;
CYA - 130
FC - 19 PPM
CC - 0
PH - 7.5
TA - 180
1 Should I drain and refill to get the CYA down, or just run a "high chlorine" pool this season, and see if the CYA drops this coming winter?
2. Will the CYA drop on its own. Pool gets used almost every day, but not very rambunctiously. Don't see a huge amount of water loss/splashout.
3. TA is high as well? What issues will this present?
Thanks in advance for the help. This site has really helped me out a ton already. Glad to have found it.
CYA - 130
FC - 19 PPM
CC - 0
PH - 7.5
TA - 180
