Not a big deal, but normally you would use a green wire for ground.
From what I can see it looks like the unions might line up except that the electrical conduit would hit the wall at the back before you could get things aligned. Is that correct? I don't know if it would help enough, but you can get right angle connectors for the flexible electrical conduit to replace the straight connector you currently have on the back of the pump. That would gain you a little over an inch.
