I just bought an AutoPilot Digital with the SC60 cell from Josh at saltpoolguys.com. If you are in the market for SWG then call them or PM JoshU first and you won't need to waste your time looking any further.
My new system will be here on Tuesday. I will install on Wednesday. What do I need to buy and do before the install?
I know I will need salt. How much salt will I need? I assume that I just buy the water softener salt from Home Depot/Lowes, right? Anything special to know about salt selection?
My current pool readings are:
FC: 11 (I'm just finishing up shocking the swamp )
PH: 7.2
TA: 90
Borates: 60
CYA: 25 (I'm currently adding this with the sock method but where do I stop?)
The water is (finally) crystal clear.
What adjustments do I need to make before the SWG?
PH: 7.2
TA: 90
Borates: 60
