- Jun 14, 2012
- 2,668
- Vinyl
- CircuPool Edge-40
Re: Getting ready to drain & refill...what do I need to know
I'd leave it alone for now - but typically it will drift up. This is more of an issue with a bleach or SWG pool than a Trichlor/Dichlor pool because these other types of chlorine contain CYA which is acidic. Also while your TA is high the PH will drift up more quickly than otherwise.
Yes - I tested daily while getting a feel for it.
azkevman said:So, do I need to lower pH? I was under the impression 7.6 was a good range for pH...jblizzle said:You CH is a little low. TA is not really something you need to worry about, it will come down as you adjust pH down.
azkevman said:OK, so basically I will need to get a feel for what my average daily FC consumption is, then add that to the min to get my dosing target...correct? Until I see what that daily average is, I am going to assume a daily loss of 3ppm to be safe. Does that logic seem ok?jblizzle said:You need to boost the FC high enough that it does not drop below the minimum by the next time you test and adjust.
