Anyone got some advice?
I'm still not 100% sure about my CYA level. It could be as much as 65 or 70....the CYA test is so subjective....the first few times I did it, I think I was trying to make the black dot COMPLETELY disappear, but based on the pictures I've seen, it looks more like you should take the reading when the dot is MOSTLY obscured.
I've added more bleach to bring me to FC 26.5. I'm going to retest at 5 PM.
The fact that I lost 7 ppm in 5 hours would make me assume I still need to continue the shocking process.
Regarding the overnight test, how many hours is the minimum you should use in between test readings? 6 hours? Test at midnight, and then again at 6 am?
