What size is your pool, are you sure it is 30,000 gallons? That sounds a bit high for an above-ground pool, mine is 27' round and holds approx 17,500 gallons.
I know of no agps that are 5 ft deep at the edge. What is the actual water depth not wall height?
I don't think you need to test for CC all the time, the important number you are looking for right now is the FC to make sure it is at shock level at all times.
.Is your filter pressure rising? Check the sand for clumping and channeling. If fine, try adding some DE maybe to help clear the water.
