I need to repair or replace one of my Jandy JVA 2444 valve actuators. From my observations so far, it appears that the motor runs but the 'toothed' shaft on which the plastic cams are mounted is not turning. So it appears that there's an issue with the coupling between the motor and the cam shaft. Repairable? Or will I need to replace the whole actuator?
Greg
Greg
