Results 1 to 7 of 7
Thread: AGP - Autopilot SWG OK?
    Mar 2008
    Tennessee
    4
    I have an 18000 gal AGP with two speed pump and 300 lb sand filter. I've done the BBB method the past couple of years (thank you PoolSolutions!) and I'm ready to move to a SWG - I'm fundamentally lazy, so keeping an eye on the chlorine level has been more work than I like! I really like the Auto Pilot SC-36 system for both features and price, but I note that the Auto Pilot website lists it for IGPs only. Does it really matter? Isn't PVC pipe PVC pipe? Isn't salt water salt water? Any help will be appreciated - I'd hate to spend that much money only to discover I've made a fundamental mistake!
    Doug in Tennessee
    My Pool - 18x24 fully setup Cabana, 22x48 gunite/quartz plaster (3-5-3 depth) & 8' spa w/ spill and 5' natural rock waterfall; Hayward DE filter/pumps/heater; Hayward Pro Logic controller; Phantom cleaner. Finished 06/01/07.
    RedishConstruction.com
    Welcome to FTP!
    Yes, you can use the AutoPilot on an above ground pool. There is a slightly higher chance of corrosion, since much of the metal frame of the pool is exposed. If you have parts of the frame that get splashed regularly you will need to hose them off occasionally to prevent salt buildup. Other than that you will be fine.
    Jul 2007
    Brisbane, Australia
    874
    Back in the days when i was installing above ground pools if the pool was supposed to be salt water we would get a bag of stainless steel screws from a pool supplier instead of the normal steel ones.
    Something for you to check, otherwise they will corrode away in no time
    Mar 2008
    Tennessee
    4
    Great, thanks for the input. I'll be putting my order in this evening! And I'll keep an eye on the screws - my wife assures me I already have several loose. I don't think she was talking about the pool, however!
    Jul 2007
    Brisbane, Australia
    874
    As long as your wife gives you the screws, you'll be right mate
    On a serious note, you would need to replace at least the screws holding the skimmer box to stainless steel ones, but i would suggest the ones holding the rails too. Of course depending on the design of your pool, because you might not have any
    And i would suggest doing it before you switch to salt, not after they start corroding away
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    I'm not sure about other brands, but ours came with all SS screws, nuts, bolts, etc
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Quote Originally Posted by garrard
    I hope you ordered from an authorized dealer and not the Internet to save some money. If so, good luck getting warranty work done.
    18 ft.52" Round Atrium AG -7600 gallons, Sand Filter, Vinyl liner, Royal Entrance Steps, 80 lbs.solarsalt
