Re: Valva leaking on sta rite filter!! Help!!
Your valve probably has a replaceable diverter assembly, the top of which is the part the handle pins to. If you take all the bolts out around the valve, you can get to the spring and diverter and see what has happened, assuming your plumbing has unions to let you lift the top off the valve.
